How hard to install universal electric antenna?
Old May 10, 2008 | 12:30 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
I have an 89 IROC and I have an electric antenna I need Installed. It goes on passenger front fender.
Old May 14, 2008 | 12:33 AM
C.M.Jones's Avatar
Car: 84 Camaro, 90Firebird, 87Transmaro
Engine: custom 5.7, 5.0 , 6.5 Turbo diesel
Transmission: 4spd, auto, auto
Axle/Gears: 2.77 posi
Re: How hard to install universal electric antenna?
short answer is it wont wok the universal shaft is too short
Old May 14, 2008 | 03:13 PM
jaykar's Avatar
Car: 87 Iroc Showcar - Saturday Nite Hun
Engine: 383 4-Bolt Truck Hyd Roller MiniRam
Transmission: B&M 700R4 - Edge 3200
Axle/Gears: BW 9 Bolt-TA Cover & Stud Kit - 3.2
As for it wont work
You may have to fab up a simple bracket but no biggie!!
Installed the universals in a few and most of the wires are
color coded the same also.
Even ordered one from GM Parts Direct for our cars and it
was universal and had to fab up a short bracket.
1" plumbers strap works great for making bracket!
Pull the fender liner and go for it
Later
Old May 14, 2008 | 03:38 PM
C.M.Jones's Avatar
well when I attempted to install one in my car I found the motor interfered with the reinforcement under the the fender I bought mine at Checker.
I went to the dealer and they wanted 120 bucks for one I looked at it and the shaft was considerably longer
the car in question was an 89 RS
Old May 14, 2008 | 04:05 PM
jaykar's Avatar
Like said, have installed 4 or 5 in our third gens and they
were all universals, Checkers, Autozone, ect, and one from
GM. The one from GM even had the correct Part# and had
to fab up a bracket.(Universal).
Had to turn ant housing a little. Thats why bracket change
if remember rite. F Body braces from 82-90 or 92 pretty
sure all the same.
One hours work after tire and shield removal and you don't have to be a fabricator to do it.
Splicing the wires took longer than making the bracket.
Clean and oil the ant every so often, common problem.
Just my limited experience with them
Later
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
Vintageracer
Jan 10, 2020 05:33 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
