Amp/sub question
Old Jul 16, 2008 | 05:16 AM
Tehsocks's Avatar
Car: 85 Camaro Z28
Engine: 6.0L LS
Transmission: T56 Magnum
Amp/sub question
Hey, i have decided im gonna buy a kicker 8" L7 solobaric sub.
Now i need an amp to run this beast, im not really up on what amps are good what are not. and also how much power i need. on kickers website it says the sub is 450RMS, and you can get it in 2 or 4 ohm versions.
its also a Dual voice coil sub.
What amp would you guys recomend. i understand i shoudl get the 4 ohm one, series the voice coils and get a 2ohm load.
but is that 450RMS at 2ohm or 4ohm? or both? kicker doesnt specify.
what amps do you recommend? brand, models, anything, i want to keep it reasonably priced ~$150
-thanks.
Old Jul 18, 2008 | 10:45 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Re: Amp/sub question
The Kicker 06S8L7-4 run 50 - 450W in 4 ohm. $150.00 CDN doesn't buy much. I take it you want a 2 channel amp
Have a look at http://www.woofersetc.com
For $150.00 try
Pioneer
http://www.woofersetc.com/index.cfm?...roduct_ID=6108
Pheonix Gold
http://www.woofersetc.com/index.cfm?...roduct_ID=5719
Soundstream
http://www.woofersetc.com/index.cfm?...roduct_ID=3175
For the money go with a Pioneer. Good performance for a good price.
Good Luck
Old Aug 5, 2008 | 03:30 AM
champnesupernva's Avatar
Car: 1983 Camaro Z28
Engine: 305, holley 4bbl. stock for now
Transmission: th200c, 700r4 coming in spring
spend the extra cash and get the kicker 650.1 (if they still make it) search ebay, or whatev....
i'd buy a dual 2ohm sub if you can find it.
Old Aug 5, 2008 | 10:59 PM
j_mangus's Avatar
On Probation
save a little more cash and do yourself a favor cause in the long run youre gonna wish you had bought the 650.1 ... my opinion... if you have to wait a week, do it.
Old Aug 11, 2008 | 07:18 PM
importkiller198's Avatar
Car: 1986 Camaro Z28
Axle/Gears: 4.10
i have a 1500 boss class D amp and it pushes my two memphis 10s really good, just its kinda hard to set to the right setting to sound perfect but once you get it then it will be awesome. i also bought a box off of ebay to fit in my hatch and it works great too.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
