how to hook up
Old Aug 9, 2008 | 11:40 PM
CroakMan's Avatar
how to hook up
i got a 1987 camaro i got an headunit how do i match the wires up to get it to work can someone help me please
Old Aug 12, 2008 | 11:49 AM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
Re: how to hook up
I just get the adapters from a store, best buy, autozone... The wires from the car plug in, and it gives you wires to tie into that say what they are.
Old Aug 13, 2008 | 11:25 AM
kanmudhog's Avatar
Car: 89 formula ws6
Engine: yes
Transmission: yes
Axle/Gears: both
Re: how to hook up
I found this on "the12volt" dot com , their usually pretty accurate .
Constant 12V+ Orange
Switched 12V+ Yellow
Ground Black
Illumination Gray
Dimmer Brown
Antenna Trigger Pink
DashLeft Front (+) Tan
Left Front (-) Gray
Right Front (+) Light Green
Right Front (-) Dark Green
Left Rear (+) Brown
Left Rear (-) Yellow
Right Rear (+) Dark Blue
Right Rear (-)Light Blue
100 th post , I'm a member now baby !
Last edited by kanmudhog; Aug 13, 2008 at 11:33 AM. Reason: copy and paste didn't lay-out very well
Old Aug 15, 2008 | 01:55 PM
jstoltz's Avatar
Car: 1987 Iroc-z Convertible
Re: how to hook up
just pay the $9 for the correct Scosche adapter. That is if someone didn't already cut the oem plugs off. You will save yourself some headaches. (especially if you ground out when you are installing)
Z28/ZR1
Oct 23, 2015 01:04 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
mcfastestZ28
Oct 1, 2015 11:23 AM
Derrick86
Oct 1, 2015 05:12 AM
Gordonr1973
Sep 29, 2015 11:59 AM
