HELP!!!
Old Feb 17, 2009 | 12:09 PM
bkenealy's Avatar
HELP!!!
my radio is really stupid, i have a kenwood and its always worked except that it goes on protect mode, i figured out that means that wires are touching, i usually can fix it by pulling it out and all that, but this time when i pulled it out, something popped, i checked the fuses on the car and on the radio they aren't blown. I connected the radio back and now it won't turn on at all. any ides would be most helpfull. Thanks
Old Feb 17, 2009 | 01:49 PM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
Re: HELP!!!
Sounds like your radio crapped out. You need to get into the compartment with a multimeter and start checking your voltages. You should have two wires that are 12+ with the ignition switch on. I am not sure of the colors off the top of my head. I think 1 is yellow and the other is orange. I would check a wiring schematic 1st and 2 grounds. If you have voltages there, Next move the stereo next to the battery and put the 2 positive wires directly on the + side of the batter and - for the ground wire. If your radio still doesn't come alive. Get the shovel and bury it or send in for repair.
Old Feb 18, 2009 | 06:35 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
Re: HELP!!!
What year car is it and and what kind of thirdgen is it(firebird, camaro). I might be able to help.
