piecing together a factory power antenna system, what am I missing?
Old Apr 7, 2009 | 08:51 PM
87350IROC's Avatar
Car: 87' IROC
I picked up a factory power antenna + relay + wires + bezel + fender nut. But it looks like i'm missing a piece where the antenna goes through the fender. It seems like there needs to be another piece to block the hole when the antenna is retracted. What am I missing. This is what I have.
Thanks for the help.
John
Old Apr 7, 2009 | 11:12 PM
V6F1R3BRD's Avatar
Car: 1988 Firebird - 1998 Z28
Engine: 2.8 - LS1
Re: piecing together a factory power antenna system, what am I missing?
im not exactly sure, but that looks like all you need. my old 86 camaro was like that before it just stopped working lol
Old Apr 8, 2009 | 12:10 AM
87350IROC's Avatar
Car: 87' IROC
Here are some installed pics. Still doesn't look right to me. Any thoughts? It doesn't fill the hole. Maybe it will look better once I get power to it and run it through a cycle?
Old Apr 8, 2009 | 03:19 PM
V6F1R3BRD's Avatar
Engine: 2.8 - LS1
thats how mine looked.. but we could both be missing something..
Old Apr 8, 2009 | 05:21 PM
87350IROC's Avatar
Car: 87' IROC
Thanks for the info V6F1R3BRD. It looks really dorky though. That hole will catch rain like crazy. Then I'll have water in my fender.
This is what I'd expect it to look like. No hole.
Old Apr 8, 2009 | 07:18 PM
V6F1R3BRD's Avatar
Engine: 2.8 - LS1
ya i think you did me more of a favor. lol that couldnt be right..
Old Apr 9, 2009 | 10:14 AM
87350IROC's Avatar
Car: 87' IROC
Hey I got the antenna wired up last night.
So the antenna is not working right. It goes up a few inches then stops and the motor keeps running, even if the key is out of the ignition. I can help pull it out, all the way up, then the motor stops like it should. Then when I turn the radio off it attempts to go down, same deal, it goes down some of the way then needs my help. I understand the common problem for these antennas is the cable breaks then the motors runs forever. It doesn't sound like I have this problem because mine does move somewhat. I'm not sure how the motor can run without the antenna moving if the cable isn't broken? Maybe the cable and gear in the motor are slipping? Does a gear move the cable?
Any ideas whats wrong with it?
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
backtothe80s
Sep 5, 2015 12:39 AM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
novaderrik
Aug 10, 2015 12:44 PM
