3RD GEN DELCO/BOSE Gold swap question
Old May 27, 2009 | 11:27 PM
MI ROC-Z's Avatar
Car: 89 IROC-Z
Engine: L98 5.7 liter
Transmission: TH700r4
Axle/Gears: limited slip 3.23
Thought I would ask the experts...
I have a 89 IROC with the DELCO/BOSE gold stereo to include the kick panel speakers, and the rear hatch speaker shelf.
Can I put a regular DELCO radio from a 2000 and up 4th Gen into my car as long as it has the 21 pin connector or does it have to be a DELCO/BOSE.
Also would a monsoon head unit work with the BOSE speaker/amp combos?
I dont want a mega system, just something with a cd player.
Any suggestions or help is appreciated.
Old May 27, 2009 | 11:43 PM
LB9Iroc87's Avatar
Car: 1987 Iroc-Z28
Axle/Gears: G92 3.23, G80, J65 disc
Re: 3RD GEN DELCO/BOSE Gold swap question
i think there were some 91's and 92's that came with a CD player in them, you might wana check into it if all your wanting is a CD player.
Old May 28, 2009 | 07:14 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
If you have a Bose setup currently, it will not work with anything else. Bose systems are meant to work as a whole and will not work the same with any stock replacement decks. There are some adapter kits you can get to work when replacing the deck, but it may not be a simple install if you're using a OE radio.
If you've already got the radio, I would recommend running new wire and installing some "standard" speakers in place of the Bose stuff. It's a pain, but will make any other future stereo changes much less of a headache.
Old May 28, 2009 | 07:46 AM
bubbatwo0_0's Avatar
Car: 87 iroc
Engine: five-seven L98
Axle/Gears: 3.27 aussie
I just went through this deal myself. I put a non bose gm radio in mine and as soon as you turn the volume barely up its too loud and it will fry your amps. You can get a converter to reduce the output of your radio to pre amp output and wire it in to your factory harness, or like i did and put in a after market head unit. I used a set of adapters that have speaker wires on one end and male pre out plugs on the other. I plugged them into the back of my head unit, and wired the other end into the factory speaker wires. Then you hook the pink wire, the one thats by itself in the radio harness, to the amp turn on wire on your head unit. Mine works great, Ive still got bose amps and speakers, but a new head unit. Hope this helps
Old May 28, 2009 | 09:47 AM
K-slice's Avatar
Car: 91' Firebird
Engine: 3.1 LH0 V6
Transmission: Auto 700R4
Axle/Gears: 3.23 limited slip
If your going to replace one piece you're probably going to have to repace it all, unless you take it to a car sterio shop. They have the equipment to rig something up that'll work.
If the only reason you want to swap is to play CD's I'd look into getting a universal CD changer. I imagine the Bose system is pretty good and repacing it with stock would be a step down. CD changers work good and only take like 15 minutes to install.
Old May 28, 2009 | 01:36 PM
MI ROC-Z's Avatar
Car: 89 IROC-Z
Thank you guys for all the good info and replies, I'm most interested in what bubbatwo0_0 did for his stereo set-up that's exactly what I was looking for. I have a cheap Sony XPLOD head unit that came with the car, and the stock Delco cassette deck but would like to use the Sony if possible. Id also consider buying a new Alpine deck to make it work.
bubbatwo0_0 can you send me more info regarding the installation you did and what part numbers/brands you used to complete it?
Frozer!!!
Jan 19, 2024 04:55 PM
Fast355
Dec 2, 2016 06:33 PM
87yellowirocz
Exterior Parts Wanted
Oct 23, 2015 09:52 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
