1984 factory radio replacement or repair
Car: 1984 z28 h.o.
Transmission: 5 speed
I have a 1984 camaro. It has the GM Delco ETR radio. THis is the one with the 5 channel equalizer. Currently my cassette deck has stopped working. I have heard rumor of these being remanufactured with provisions for an audio input. Either way I am looking to maintain my stock appearing deck(so please don't post anything besides stock replacement ideas!). Any solutions?
Thanks.
Thanks.
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Re: 1984 factory radio replacement or repair
You can pull pretty much any tape deck from pretty much any GM of similar years or even newer.
Or go way newer but still stock looking , you will only have to change the plug , you can find factory adapters that goto your harness to the newer one in cavaliers.
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
That radio pictured above has a 9-pin auxiliary input on the back for driving a slave unit (cassette or cd changer). You can use that to add another audio source with an adapter such as this one.
http://www.discountcarstereo.com/detail.aspx?ID=347
The head unit in my 89 looks just like that one pictured by The_Wraith except it is a CD deck, I plan on using the GM9-AUX to hook up a Siruis receiver and play through the CD changer input.
Car: 1984 z28 h.o.
thanks, but as in stock replacement i mean stock for my car. I am looking for a radio with a cassette deck and the equalizer that is the SAME as mine so it will look STOCK.
Car: 1984 z28 h.o.
here is a link to help confusion
http://www.cardomain.com/ride/3211747
this car almost has my deck
I am unable to find an exact photo and may have to take one and post it tomorrow
colton_carlson
Mar 8, 2019 12:21 PM
