I want radio.
Old Oct 31, 2009 | 09:13 AM
Mr Froman's Avatar
Car: 1990 Firebird Formula
Engine: LB9 - 5.0 TPI
Axle/Gears: 2.73, LSD
I want radio.
I had my antenna shaved because it did close to nothing in the first place, but now I decided I want radio. I looked it up in my Chilton and it's pictures were pretty useless and so was the description considering I know nothing about my radio. I was looking around for universal antennas, but even then I don't know how to hook it up. Anyone know what I should do?
Old Oct 31, 2009 | 10:34 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: I want radio.
hooking up an antenna is fairly simple if you're not getting a powered/amplified one. If you've got a factory GM radio, you will need an adapter though (can be found at any part store). Some people have had good luck putting a standard "whip" antenna underneath their dash cap and run the cable to the deck.
The end that connects to the radio will look kinda like an RCA end (the red/white/yellow connectors you have on your dvd player at home). it just plugs right into your radio.
Old Oct 31, 2009 | 11:48 AM
Mr Froman's Avatar
Re: I want radio.
So does that mean I have to do anything to my dash?
Old Oct 31, 2009 | 01:41 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: I want radio.
You don't have to do anything to the dash except to remove the dash pad to place the antenna under it. Then replace the pad. The wire runs down through the center of the dash alongside the defroster ductwork to where the radio is at.
Old Oct 31, 2009 | 04:03 PM
Mr Froman's Avatar
Re: I want radio.
So should I just get a universal antenna and feed the wire down to the radio from the dash and hook it up?
Old Oct 31, 2009 | 04:07 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Re: I want radio.
That's what I did. Use a regular antenna though. I used one of those universal "hideaway" antennas that are designed to slide down into a the A-pillar or fender and I don't get very good reception with it.
Old Oct 31, 2009 | 05:33 PM
slow305rs's Avatar
Re: I want radio.
You could use a factory antenna/base from a 07 Pontiac vibe and mount it on the roof near the rear hatch. All the parts you need could be had from your GM dealership.
OR.....XM radio
Old Nov 9, 2009 | 06:48 PM
Mr Froman's Avatar
Re: I want radio.
What is the adapter for?
Old Nov 17, 2009 | 07:24 PM
86irocmv's Avatar
Car: 1986 iroc-z
Engine: 5.0 tpi 305
Transmission: auto
Re: I want radio.
hi all
i am looking for a factory radio "ux1" code radio for my 86 iroc z-28 does any one have one for sale? must be the code "ux1"
thanks
mike
please send reply to this post
thanks
Old Nov 22, 2009 | 09:20 PM
Mr Froman's Avatar
Re: I want radio.
I found my antenna cable, but it is taped to another, much thinner, cable that runs up my passenger side fender and under my hood. What is that?
Old Nov 23, 2009 | 02:55 PM
Mr Froman's Avatar
Re: I want radio.
Ok, this isn't working at all like I thought. I bought an antenna cable because my old antenna cable was cut. So I have adapters, universal antenna and an antenna from an 09 dodge ram, but I can't figure out how to hook the antennas up to anything because nothing has threaded ends to screw the antenna into. Any help would be great right now while it's apart.
Old Nov 23, 2009 | 05:44 PM
polaris91's Avatar
Car: 88 camaro z28
Re: I want radio.
it shouldent be threaded it should just push into a spot in the radio
Old Nov 23, 2009 | 08:52 PM
Mr Froman's Avatar
Re: I want radio.
The spot that pushes into the radio is like that but the antenna itself is threaded, so I guess I need part of the antenna mount or the antenna assembly OR SOME KIND OF ADAPTER?!
EDIT: In case I was not clear, it is connecting the actual antenna itself that I am having trouble with...
Old Nov 23, 2009 | 09:05 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Re: I want radio.
Yes, the antenna cable threads onto the base of the antenna mount and then the antenna threads onto the mount. At least, that is how GM and older Dodge antennas are connected. I imagine the newer Dodges are similar. You might be able to thread the antenna cable directly into the bottom of the antenna using a piece of threaded rod or a screw with the head cut off.
Old Nov 23, 2009 | 09:09 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Re: I want radio.
just get this
http://www.crutchfield.com/S-tz53bYj...wAll=N&tp=2369
Old Nov 23, 2009 | 09:22 PM
Mr Froman's Avatar
Re: I want radio.
Originally Posted by TPl383
Heard they didn't get good reception...but I might have to. No adapters out there?
Old Nov 23, 2009 | 09:39 PM
tman89's Avatar
Car: 1989 Firebird
Engine: 2.8L V6
Re: I want radio.
I just hooked up a universal rubber ant. from my local auto parts store. The connections did not fit tight so all I did was connect them together and taped it up. It works fine!
Old Nov 24, 2009 | 07:41 AM
Mr Froman's Avatar
Re: I want radio.
I don't know how much clearer I can get. I don't have the antenna mount assembly anywhere to change it from the female AUX end of the antenna cable to the threaded female/male end of the antenna.
BRoss99
Aug 10, 2025 05:08 PM
69 Six Pack
Oct 5, 2015 07:51 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
DonW
Aug 24, 2015 08:24 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
