Sub choice questions
Old Jun 5, 2010 | 02:40 PM
sakattack28's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Axle/Gears: Stock
so im finally getting around to finishing up my sound system. im going for a complete alipine system, so i have Type R 6x9s and Type S 4x6s. i have my sub box almost completely done (thanks to the sticky thread on the boxes), and now im picking out which subs i want. i am going for two 12" Type R's but i dont know which ones to get, the 4 ohm DVC or the 2 ohm DVC ones. right now i have a Legacy LA690 1000 watt amp im going to use but thats purely because of cost, and im thinking of getting an alpine amp sometime in the future (read: a really really long time) so i was wondering which would be better, if i want a good system now and when i get a new amp. i was thinking the 2 ohm ones, but im not quite sure if thats what i should be getting. if anyone has any suggestions i would be very appreciative.
Old Aug 10, 2010 | 11:59 PM
Brewster91's Avatar
Re: Sub choice questions
it really all comes down to what your am can handle as far as "ohm load." 2 ohms are usually better for SPL (sound pressure level) but it depends how you wire them. in a series 2 ohms combines to a 4 ohm load but in a parellel circuit it ends up being a 1 ohm load
Old Aug 11, 2010 | 11:11 AM
87350IROC's Avatar
Car: 87' IROC
That amp can only only do 4ohm subs when bridged. So you should get the dual 2ohm alpines. This will work well once you get a decent amp, as they can be parallel wired for 2 ohm.
My only question would be. Why would you spend money on 2 decent subs and 1 really crappy amp? Instead of 1 decent sub and 1 decent amp?
Old Sep 1, 2010 | 02:40 AM
RavenTA's Avatar
Car: 87 Trans am
Transmission: 5 speed
If your going for sound, Get the 2 ohm subs and wire them to 1 ohm and invest in a better amp best amps for running 1 ohm are the mono amps
Question: are you set on doing a alpine amp if not I suggest hifonics (brutus series) they handle power great and most of their amps are 1 ohm stable, For your set up i would suggest this amp
http://www.hifonics.com/Hifonics_Brutus_BRZ_Amps.html
And you need the BRZ1200.1d (the first amp listed)
Old Sep 2, 2010 | 07:19 PM
Car: 1991 Camaro RS
Engine: 305 TBI
Axle/Gears: Stock
sorry for taking so long all, but ive been moving, and starting school again, so ive been busy, sound system is done, i went with the 4 ohm subs, and mark fried the legacy amp, so i wen out and bought a 1000w alpine amp. ill put up pics when i get time, and which amp it is. it hits hard. so awesome.
camaro71633
Sep 1, 2015 10:24 AM
BlackphantomZ28
Aug 22, 2015 01:00 PM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
