Factory radio...amp...subs
Old Jul 18, 2010 | 11:03 AM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
Can an amp be hooked up to a 88 factory cassete so that I can run subs?
Old Jul 18, 2010 | 11:14 AM
Dr.NickRiviera's Avatar
Car: 1987 Trans Am
Engine: tree-fiddy
Re: Factory radio...amp...subs
There is a line adapter that you can connect to the rear speaker wires and run that to your amp.
http://www.crutchfield.com/S-8tln61B...=detailed_info
Old Jul 18, 2010 | 11:15 AM
Azrael91966669's Avatar
Car: 1991 camaro RS
Engine: CharlesOdoryOB
Transmission: 82513892892
Axle/Gears: pbr disc 3.27 nine bolt
yes as long as the amp uses high level inputs
Old Jul 18, 2010 | 01:37 PM
Axle/Gears: Posi
So when I buy my amp make sure it has high level inputs in it? These connect to the adapter? How do I connect to the radio, is it with the same adapter?
Thanks in advance.
Old Jul 18, 2010 | 02:19 PM
SolarGoldRaptor's Avatar
Car: 1984 Pontiac Firebird Trans Am
Engine: V8 5.0L HO (L69)
Transmission: B&W T5
Axle/Gears: 3.73 limited slip
The option UQ7 included two subwoofers and an additional amp to power them, so there is no reason you couldn't add one. It includes a separate harness in the dashboard and a specific rear speakers harness.
To bad I don't have pics of the parts but I'm sure a little research would help you.
I'd be curious to know the output of this amp.
Old Jul 19, 2010 | 09:26 PM
Axle/Gears: Posi
I am still looking for more information on this. any other ideas how I can hook up the factory radio to an amp?
Old Jul 19, 2010 | 09:53 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
couldnt he use an inline converter? correct me if im wrong but i think thats all he needs
Old Jul 19, 2010 | 10:10 PM
Axle/Gears: Posi
How do those work? Who sells them? Can I install it or do I need to do it professionally?
Old Jul 19, 2010 | 10:14 PM
Engine: L31 350
These connect to your rear speakers and allow you to run your subwoofers if you run on a factory radio, you should be able to pick them up at any electronics store.. and you can do it yourself its almost like speaker wire.....here is an explanation http://answers.yahoo.com/question/in...0064503AAS2IBL
Old Jul 20, 2010 | 12:12 AM
Car: 1991 camaro RS
with high level inputs you tap into the speaker wire
for example im useing a high level amp run off both my rear speakers to power a dual channel sub its a sub ment for a home stereo it was free and works just fine
high level inputs convert the signal to line level inside the amp instead of useing converter boxxes
or you can buy line level converter boxxes and run a normal amp
im running a jenson 300w amp off a factory head unit to power a 12 i just wanted a little extra bass
my sub is hidden in the rear comparment cubby the amp is hidden the spare tire well
it took about 2 hours to install
it worked great for me but
i bought one of the 20 dollar amp hook up kits from walmart
amp was garbage picked as was the sub
Old Jul 22, 2010 | 12:41 AM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
I (literally) JUST bought one of these to work with a factory radio that I put in my camaro.
http://shop.ebay.com/?_from=R40&_npm...+LOW+LEVEL+402
Seems to work fairly well, just seems like the subs are alot louder than they were.
Old Jul 22, 2010 | 12:36 PM
Axle/Gears: Posi
Thanks. That is what I want to do Azrael91966669. Add an amp plus subs to the factory unit.
Thanks for the details evilemokid94.
Now I just have to figure where to put the subs in the vert.
Old Jul 22, 2010 | 12:38 PM
Axle/Gears: Posi
Do you have an amp and where do you have your subs placed? I have the same car as you.
Old Jul 22, 2010 | 12:40 PM
Yes sir, I have an old 800watt MTX(??) amp, and 2 12" subs in the trunk.
Its not pretty, the box was actually made for 4th gens, but I cut the lip of the box off, to drop it in the trunk.
Old Jul 22, 2010 | 02:48 PM
Engine: L31 350
any time, feels good to help someone.
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
Galaxie500XL
Oct 1, 2015 01:05 PM
