Power antenna question (with pic)
Old Nov 16, 2010 | 10:00 AM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
I bought a new antenna mast from MDM, and everything appears to be correct except that the new mast lacks the tab for the mounting bracket. Isn't this what keeps it from wobbling around inside the fender? Any ideas on what I should do here?
Old Nov 16, 2010 | 10:23 AM
87350IROC's Avatar
Car: 87' IROC
Re: Power antenna question (with pic)
I bought a mast about a year ago and I think what i did was cut out a u-shape with the dremel near those 4 holes. Then I just bent it up to create the tab.
Old Nov 16, 2010 | 10:27 AM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Yeah it appears that's the way the stock one was. I was trying to avoid that but I may have to give it a try.
Old Nov 16, 2010 | 10:33 AM
87350IROC's Avatar
Car: 87' IROC
Yeah not the cleanest way to do it. But it has been working well for me so far.
Old Nov 21, 2010 | 05:37 PM
chads89ta's Avatar
Car: red 89 t-top ta
Engine: 305 tpi
Transmission: t-5
Axle/Gears: 9 bolt soon
you can fix the plastic internal mast with stihl brand weed trimmer line, that is .135 in diameter
Old Nov 21, 2010 | 06:05 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
My antenna was bent, which I think is what caused it to break in the first place.
I got it fixed though, I assembled it with the antenna extended, then when I plugged it up it went down like it's supposed to.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Aug 16, 2015 11:40 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
