3.5mm input with switch
I've successfully set up an aux input on my 91 camaro, but now I need one more part. I'm inputing the signal from the radio board before it hits the amp. (which works much better than cassette IMHO) Now instead of using a physical switch, I've seen people use the 3.5mm jacks that are closed when nothing is plugged in, and open when you plug in a source. Where can I get one of these? I'm really hoping radio shack has them, and if so, can I get an item #?
Thanks,
Joe
Thanks,
Joe
Car: 87 Trans-Am, WS6
Engine: 5.0 TPI
Axle/Gears: 4.10 Posi
Re: 3.5mm input with switch
Radio Shack #274-246 for $2.49. Can you post how you performed your setup on the radio board. I have used this jack but I have to have a casette playing and I would rather have a direct input.
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
FormulasOnly
Sep 10, 2015 09:07 PM
Randomtask2
Sep 10, 2015 08:37 AM
