UQ7 gain switch & amp
Old Apr 6, 2011 | 07:55 PM
P0150N's Avatar
Car: 1987 GTA, Digital Dash,T-Tops
Engine: 5.7L, L98 350 CID
Axle/Gears: 3.27 Aussie 9 Bolt
hello guys,
I think somehow my factory amp got fried while welding in my sub frame connectors. My battery was disconnected before the weld in, but I lost my amp right after that.
The light turns on for the gain control but I dont hear the amp power on, nor do I hear my subs kick in or get a response when I slide the gain control ****..right or left
any inputs?
sincerely,
Lennie
917.941.8332
LeonardLedra@hotmail.com
Old Apr 7, 2011 | 06:10 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: UQ7 gain switch & amp
The amp is easy to get to, it's located just behind the plastic panel under the map pocket. On the amp, check for:
12v on the pink wire at pin #13.
Ground on the black wire at pin #14.
Old Jun 1, 2011 | 08:17 AM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
It maybe the gain switch itself,they do go bad.I replaced mine awhile ago and that fixed the problem.
HP52TA
Feb 3, 2018 10:51 PM
tglennon11
Sep 23, 2015 05:30 PM
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
Randomtask2
Sep 10, 2015 08:37 AM
1Aauto
Sponsored Vendors
Sep 8, 2015 11:14 AM
