Need some advice on fixing my factory radio
Old Sep 4, 2011 | 05:30 PM
Baja B4C1LE's Avatar
Hello all, great site. I did some searching but I still need some help, I know nothing about stereos.
I have a new to me 92 RS that has the factory AM/FM/Cassette player that only has sound coming out of the front left speaker. I need to buy several things for the car and funds for a new stereo are a ways off, so I'd like to get the factory system working on all 4 speakers if possible. Where do I start? How do I check to see if the radio or speakers are the problem?
Old Sep 5, 2011 | 04:58 AM
HisDivineShadow's Avatar
Car: 1991 Trans Am GTA
Engine: 350 TPI (L98)
Transmission: TH-700r4
Re: Need some advice on fixing my factory radio
Well this would be a good start:
Shows you which cables are connected to what.
Old Sep 11, 2011 | 08:20 PM
lsd88ta's Avatar
Car: 1988 Firebird Trans Am
Axle/Gears: 3.27:1 LSD 9 Bolt Disc Rear
my factory radio has a similar problem, only the left rear works, I tested the other speakers on a different radio and they play fine..the wiring appears fine.. so it may be the head unit..I'm not sure what can be done on the inside of those things...maybe hit it with a hammer.. I'm joking.. I'm probably just going to go to a CD player.. but make sure you get the wiring adapter so you don't have to cut up the factory wiring.
Old Sep 11, 2011 | 08:25 PM
The speakers tested bad, so I bought some new ones. It helped a little, but the head unit still has issues. After doing a lot of internet reading it looks like the parts are not available to fix it, so I'm going to have to get an aftermarket unit. I know it will sound better, I was just hoping to keep the factory look.I
Old Sep 11, 2011 | 10:57 PM
*84TA's Avatar
Car: 84 Trans Am
A lot of times it is the capacitor that goes bad on the channel that is not playing. A quick test with a multimeter should tell you.
Baja post a pic your radio. I may have a spare lying around.
Old Sep 12, 2011 | 05:05 PM
Here it is.
Old Sep 12, 2011 | 10:01 PM
*84TA's Avatar
Car: 84 Trans Am
Check your PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
89gtaforsale
Aug 24, 2015 09:32 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
