Headunit restarts when volume is raised.
Old Nov 29, 2012 | 02:45 PM
thewhitestripes's Avatar
Car: 1988 iroc
Engine: 350 tpi
Transmission: t-5
Axle/Gears: stock
I'm not to sure how I'm supposed to go about diagnosing this issue but I've had a ken wood unit in my car for over a year now with no problems but recently this: whenever the volume is raised to a considerable doin level the radio resets itself and will continue to do so untill I turn it down slightly. It will progressively get worse untill it stops working completely. Any ideas?
Old Nov 29, 2012 | 03:53 PM
Ruckusz28's Avatar
Car: 1986 IROC-Z
Axle/Gears: 4:10
Re: Headunit restarts when volume is raised.
Sounds like a bad ground or you have a shorted speaker.
Old Nov 30, 2012 | 08:34 PM
5speedswap's Avatar
Car: 86 trans am
Engine: 1974 caprice 350, mild cam
Transmission: T5 5 speed
Axle/Gears: 3.43
it sounds kind of like the voltage is low. i had a car with a dead battery once and i figured i would listen to the stereo and it did the exact thing. bad wiring maybe? just a thought
Old Nov 30, 2012 | 09:02 PM
jaybdaboat's Avatar
Car: 1987 Sports coupe/z28
Engine: 2.8/ swapping 5.3
Axle/Gears: Open 3.42
Check your power, grounds and speaker connections
Old Nov 30, 2012 | 10:31 PM
chucks_net's Avatar
Car: 91 Z28
Engine: worked crate 350
Axle/Gears: Z posi
Its going to be your power source as mentioned + or - has a poor connection
Old Dec 12, 2012 | 09:45 PM
Car: 1988 iroc
Engine: 350 tpi
Transmission: t-5
Axle/Gears: stock
To clOse out the thread: it's was the harness that connected into the radio. Figured it out by chance when I accidentally put pressure on the base of the harness and it turned on, took pressure off and it turned off. Got a new harness and bam, it works!
Linson
Oct 24, 2025 02:00 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
3rdgenkindagal
Sep 13, 2015 02:02 PM
Ranbo108
Sep 9, 2015 12:20 PM
TheExaminer
Sep 6, 2015 11:40 PM
