trans am radio pod removal?
Car: 1991 Trans Am GTA
Engine: L98(5.7 L TPI)
Transmission: 700r4(A4)
Axle/Gears: G80 RPO, 3:23s, Auburn Racer's Diff
How the heck do you remove the radio pod on a '91 'bird?
I removed the 5 bolts that face the rear of the vehicle. Plus another 2 on the inside. it still won't come out. I'm trying to remove a 10mm bolt off the "floor" of the radio pod area. I've loosened that bolt all I can, but it wont come off the threaded studd its screwed on to.
thoughts?
thanks!
Bill
thoughts?
thanks!
Bill
Re: trans am radio pod removal?
got all the bolts out, but it seems like I need to remove the center console to get this freakin thing out
Car: 1991 Trans Am convertible
I had to remove the console to get it out. You might be able to twist it around after you remove the shifter handle.
Car: 87 Trans Am, 99 WS6, 16 Mustang GT
Engine: LB9, LS1
Transmission: 700R4, T56
Axle/Gears: 3.42 Posi, 4.10 Posi
It only took two bolts to get the radio pod free in my car. They were 10mm, where the pod meets the dash.
