Power antenna radio not working
Car: 1990 Iroc Z Red Vert
Axle/Gears: Stock
Just purchased a 1988 Iroc Z with a power antenna radio. The clock on the face of the radio is the only thing that works with the key on. I took the radio out and checked the plugs and antenna is plugged in. Antenna is stuck in the up position. I heard that the power antenna cars have issues but never had one until now. ALSO ,the fog lights dont work. bulbs were burned out. put in new bulbs and still dont work. The small light on the fog light switch does not come on when I turn the switch on. Any help to fix would be great. THANKS JIM
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
Re: Power antenna radio not working
your car have the bose radio? if so the power circuit for the amps could be out.
Car: 87 bird
Axle/Gears: 4.10
as far as the fog lights you have to check the fuse and see where you have power and dont.
colton_carlson
Mar 8, 2019 12:21 PM
