Soebody who knows, please respond!!
Old Sep 16, 2000 | 12:27 PM
myposcamaro's Avatar
hey ok heres the problem. I got a cd changer installed awhile ago and its hooked up to the stock radio in my 84 camaro, and mounted in the back. Now i need to install an amp to my subs. I need to know how i can install the amp to the radio? theres no REM jack in the back of it or anything. The radio is weird too, it stands up out of the console and has a built in equilizer and everything. Its the weirdest lookin thing ive ever seen so i wanted to keep it in there rather than getting a new Head Unit. So can anyone help? i just need to know how to run the wires for my amp.. thanks!
kev
Old Sep 16, 2000 | 01:20 PM
admrlam's Avatar
You will need to go to local stereo shops, i know there is an adapter that will allow you to install an amplifier to the factory deck, ive seen it done in a pontiac sunfire. I dont, however, think it will be a great quality setup. With some decks, you can get a separate pre out for the subwoofers, and get more control for them in that sense... Also, i wonder, if you run the other speakers off a factory deck, i wonder if the subs are goin to drown them out. Ive run in to this problem with aftermarket deck power, which is surely greater than the power coming out of the factory deck.
Surely this idea of yours WILL work, but i truly think youd be better off biting the bullet and replacing the head unit, but thats just MHO.
1988 Formula, 305TPI, 700r4(for now), headers, stage 2 PROM, modded MAF, cat back, no catalytics, cowl hood, centerline champ 500 rims, KOBEL predator ground effects kit, Trans AM tailights, dash pouch, 92 shift console w/indicator, white face gauges, accented red trim, 12 speaker stereo, 4 amps, tint, T tops... icq 44373460 AIM:admrlam
see it at www.geocities.com/admrlam/bird.html
Old Sep 16, 2000 | 02:37 PM
scoob8000's Avatar
Car: 95 Caprice
Engine: 5.7l LT1
Axle/Gears: 2.93
you dont need any adapter, just run a wire from any switched 12v+ wire off your ignition to the remote input on the amp, it will come on whenever your ignition is on
Old Sep 16, 2000 | 05:30 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
You WILL need an adapter unless the amp has high level inputs. You'll need a line-level converter to convert the speaker outputs to line level so that the amp can accept it. The radio you described sounds like the swivelling Berlinetta radio. It's basically just as worthless as the standard Delco radios, and how it managed to survive 16 years is totally beyond me.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Sep 16, 2000 | 05:38 PM
umm how do i hook it to the ignition?!?
you have to explain everything to me cuz im rather new to this, and have no clue about installation. ALSO.. i have almost no money for "adapters" and whatnots so if anyone could make a small list of what i might need?
-thanks
-kev
Old Sep 18, 2000 | 02:33 PM
ok amps installed! let me tell the story!
originally i ran the remote wire and tapped it into the remote wire from my cd changer, then i started experiencing trouble. next thing i knew my cd changer would not turn on and neither would the amp, i couldnt even eject the changers CD magazine. ANYWAY.. after much troubleshooting,and reading.. i finally came up with a plan. To take some of the extra remote wire.. strip the end.. and shove it into the empty fuse location for "IGN"..I automatically assumed it stood for Ignition. then tapped that remote wire to the head units remote. the amp turns on and off with the ignition just like scoob8000 said it would. installing amps isnt hard at all.. thanks to all the people at thirdgen!
1992Z28!
Nov 19, 2015 07:33 AM
L98GTA87
Oct 19, 2015 10:43 PM
2012sergen11
Interior Parts Wanted
Sep 7, 2015 11:37 AM
luvofjah
Aftermarket Vendor Review
Aug 31, 2015 11:22 AM
