singal or dual voice coil
Old Nov 1, 2000 | 03:38 PM
85camaroz28's Avatar
which is better and why?
Old Nov 1, 2000 | 05:59 PM
Trnsam87's Avatar
You definitely want to go with DVC.These pound alot harder. Heres a link that gives you a legnthier discription instead of me typing it out in words. http://www.jlaudio.com/tutorials/dvc/
Hope this helps. ~~Jaime~~
1987 TransAm
350 sbc
Holley 750 Vac sec
Edelbrock Performer Rpm Heads/Intake/Cam
Flowtech Ceramic Headers
Crane Roller tip Rockers/pushrods
Flowmaster Muffler
Old Nov 2, 2000 | 02:42 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Duals can take more power, hence, they are louder and cost more.
-Justin-
T-Top '86 5.0L LG4 700R4 WS6 Now Bilstein equipped!
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 9/18/00)
There can be only one!!
Old Nov 2, 2000 | 08:35 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Here's a real answer. It depends on your application. DVC doesn't pound harder just because it's DVC. You want to choose your subs based on the impedance that will give you best performance. DVC subs tend to give you more flexibility, which is good if you're going to add another sub later or change amps, etc. The lower the impedance is, the more power the amp makes. Paralleling the 2 coils on a DVC sub makes for a lower impedance, but in many cases it could be to low for the amp. You want a total subwoofer impedance that matches the lowest impedance that the subwoofer amp is rated to safely handle. If it's rated for 4 ohms bridged, then that's the impedance you want from your subs. That means parallel 2 SVC 8 ohm subs, or Series/Parallel a pair of DVC subs. If you're running just one sub with an amp that is stable into 2 ohms bridged, then the DVC sub will give you an advantage.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Nov 2, 2000 | 11:54 PM
bill wilfred's Avatar
dual voice coils are better cause they have a bigger magnet
Old Nov 3, 2000 | 07:49 AM
Jim85IROC's Avatar
That's not true. A bigger magnet doesn't mean jack crap. A magnet properly designed for the specific driver is what's important.
The IROC Homepage
Old Nov 20, 2000 | 06:37 AM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
I agree with jim85iroc. The dvc design doesn't mean more bass or a more powerful speaker. Radio Shack makes dvc's that are weak. The thing that matters most is that the impedence (ohms) match your amp.
ZEEYAA
Apr 16, 2023 08:29 PM
jrdturbo
Mar 31, 2016 02:58 PM
92rsvortec350
19
Oct 9, 2015 09:39 AM
Night rider327
Oct 9, 2015 09:25 AM
Giocio
Oct 1, 2015 12:20 PM
