92 Camaro Din Size
Old Apr 18, 2017 | 04:22 PM
Dshipp1992's Avatar
92 Camaro Din Size
Is the 92 a 1,2,or 1.5? I'm about to buy a new head unit and want to make sure I get everything I need for a clean install. Thanks guys
Old Apr 18, 2017 | 04:57 PM
dbrochard's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: WC T5
Axle/Gears: Torsen 3.73
Re: 92 Camaro Din Size
1.5 factory, but you can get an install kit to do a single din, and some member have moved things around to squeeze in a double din. But the easiest, factory way is to find a 1.5 din headunit
Old Apr 20, 2017 | 05:53 PM
cdoyle's Avatar
Yes it's 1.5 factory.
But you can modify your bezel to get a double din in there.
There is another thread on there where someone is creating a file for a 3d printer too.
Old Apr 21, 2017 | 08:07 AM
7thdarkangel's Avatar
Car: 1983 Camaro
Engine: Missing
Transmission: Missing
Axle/Gears: 9" Ford
Standard plate modified for the double din is located in my sig. The flipped version(radio above hvac controls) is in progress.
