Is it possible to get bass from 6x9's in the standard placement location?
Car: 1991 Trans Am
Hi Everyone,
So I redid the stock speakers the other day and also installed a newer head unit.
Front Speakers: Infinity REF6432CFX
Rear Speakers: Infinity REF9633IX
Head Unit: JVC KD-R990BTS
Speakers sound clear but there's no bass, I mean no bass. If I turn the EQ bass settings up or turn on bass boost it's more of a POP than anything resembling bass.
Any thoughts on this? Based on the enclosure of the stock 6x9 location is it a losing battle to try and get bass out of 6x9's?
I'm trying not to run an external amp or install a sub, but perhaps that's my only option if I'm not satisfied with the current sound.
Re: Is it possible to get bass from 6x9's in the standard placement location?
Not saying you did, but IF you wired the speaker polarity wrong on 1 channel, L or R, then the bass from 1 side would cancel out the other side - net ZERO bass.
What happens when you use the balance and fader controls?
Car: 1991 Trans Am
Just tired that, tried rear only one side at a time, no change. I'm wondering if I'm missing a setting somewhere on the head unit. I'll keep playing around with it.
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Ditch the rear Speakers and get something that will produce some bass.
The stock 6x9 was a 6x9 woofer,........ not a 2-way,..... not a 3-way. The stereo in a third gen is "configured" to throw highs right in your face and only get lows from next to/behind the passengers. ( IMO ! ---> ) By using a 3-way speaker back there your adding way too much mid and high range from the rear.
[/300W Max 6x9" 3-way Car Audio Speaker with Edge-Driven, Textile Tweeters - Pair
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
You can fit 8” subwoofers in the 6x9 location with minimal modification
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Are the foam enclosers still in the panel? Those make a difference if they're missing.
Steve86TA
Nov 24, 2006 08:02 AM
Xenodrgn
Car Audio
19
Aug 31, 2002 04:38 AM
