please help
Old Jan 17, 2002 | 02:49 AM
jester111's Avatar
please help
Hey Guys I got a little problem pleas help me!!!
I have a stock GM radio out of a 91 z28, but I dont have the plug for it, what I need is to hrd wire the deck but dont know the wire placement. looking at the deck from the back right side up there is 7 pin con. left side, 4 pin con. on the right( thinking this is the front speake plug), 4 pin con. bottom left ( thinking this is the rear speaker plug) , and a 6 pin con. on the right. If I got the speaker connectors right then what Im looking for is the 7 and 6 pin wire color codes. A picture would be nice but not nessesary if reply is detailed.
Any help would be greatly appreciated!!!
Thanks in advace!!!
Old Jan 17, 2002 | 07:10 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Get a harness out of a junk yard. It'll make your life MUCH easier.
What year car is it going into? If it's another thirdgen, the wire colors should be the same between the new harness and your stock wiring.
Old Jan 17, 2002 | 07:30 AM
deadtrend1's Avatar
if you cant get to a junkyard and get a harness, get out a 12volt test light and go to this part of my page. I have a little thing that helps you find what wire is which.
http://home.earthlink.net/~deadtrend...headunits.html
Its cheezy but should help
Old Jan 17, 2002 | 02:42 PM
jester111's Avatar
hey guys
its not going in a third gen and i cant get a plug for it. what i need to know is what are the pins for the 7pin plug and the 6 pin plug.
thanks
