Wanted: AM/FM/cassette Radio Wiring Harness
Old Nov 12, 2021 | 01:44 PM
72buickgs's Avatar
Car: 1984 Trans AM
Transmission: 700-4r
Since the "Wanted Thread" is closed, I am placing my ad here. I am looking for the am/fm/cassette wiring harness that plugs into the back of my GM ETR radio for my 1984 T/A. I have the orig radio. The previous owner replaced the ETR with an Alpine am/fm/cd player which does not work well. Whomever installed the Alpine cut all the original wires in the harness & soldered in a smaller plugin wiring harness as required by the Alpine. Should be the same for a Camaro. I am attaching two pictures which either one may be correct
Let me know.
Old Nov 12, 2021 | 07:19 PM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
Re: Wanted: AM/FM/cassette Radio Wiring Harness
I don't see the Parts Wanted forums being closed. Maybe members are required to have xx amount of posts before they can post ads? I don't know. Some forums have such requirements.
Anyway, the adapters in your pics are the female ends(like in the back of your radio). But you need to splice a factory male end back onto your cut wires, correct? Here's a pic of mine, which should be what you're looking for. And below that is a pic and link to them. A web search showed a Walmart link, but it's probably available anywhere.
This is my car's harness above. This is what you're missing, right?
And here's the link to purchase that segment.
Metra 71-1677-1 Reverse Wiring Harness for 1978-1990 GM Vehicles 12-PIN Factory Radio - Walmart.com
Old Nov 13, 2021 | 09:54 PM
72buickgs's Avatar
Car: 1984 Trans AM
I checked the link u mentioned but when I access it, the check for fitment fails for the 1984 Firebird.
Old Nov 13, 2021 | 10:44 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
$13 shipped,.... send me a PM if your interested.
P.S. Got a Power Antenna ??
Derek The Great
Car Audio
Apr 18, 2010 08:28 AM
johnnyboy
Interior Parts Wanted
Nov 2, 2006 08:36 PM
FruityOne
Mar 15, 2003 06:10 PM
pauldaniel26
Car Audio
Jul 30, 2002 10:50 AM
