Power seat wires, useable?
Subscribe
Sep 30, 2023 | 08:59 AM
Hey Folks,
My car used to have a power adjustable driver's seat. The power worked but the seat frame was falling apart so I replaced both fronts seat with manual Procar Scat seats. I'd like to add a small powered sub and was wondering if I could use the leads for the seat to power it?
Thanks!
Reply 0
Sep 30, 2023 | 11:57 AM
Re: Power seat wires, useable?
I wouldn't recommend it. Even small amps recommend at least 8g wire for power and ground, and the wires for the seat aren't that beefy. They're fine for quick adjustments of a seat, but wouldn't stand up to the continuous use. You're better wiring everything yourself from the batter back, to be sure it's up to the task.
Reply 0
Sep 30, 2023 | 04:21 PM
They are 10 Ga. wires attached to a 30 amp circuit breaker.
Reply 0
Oct 1, 2023 | 12:13 AM
How big of an amp? I know the Infinity Primus 6002a works with a 10g wire, pushes 140 Watts.
Reply 0
Oct 1, 2023 | 03:38 PM
Quote: How big of an amp? I know the Infinity Primus 6002a works with a 10g wire, pushes 140 Watts.
I was planning on getting one of those underseat size amps.
Reply 0
Oct 14, 2023 | 02:11 PM
I wouldn't recommend it. Just run new wire and fuse it near the battery.
Better to be safe than car on fire.
Reply 0
Subscribe
