Where to hide the wires?
Old Apr 20, 2001 | 11:03 AM
mcconahay37's Avatar
Hey guys. Where did you hide the wires for your system? Right now, I have the wires running from my amp to the top of my box. I'm going to be building a new box pretty soon, and I don't want the wires to be visible, or at least not very noticeable. I also want to be able to easily disconnect the wires so that it's not much of a hassle to remove my box when I pull it to go race.
82 Camaro:
350, Erson cam, ported heads, Crane Hi-6 ignition, Accel supercoil, Comp Cams 1.6:1 rocker arms, TH350 tranny with 2500 stall.
Old Apr 20, 2001 | 02:30 PM
Hummer's Avatar
Car: 1986 Z28
Transmission: 700-R4
I may have a different setup than you, since I built a permanent box that I will never be able to remove. I ran all the wires under the carpet and under the plastic panels that are above the wheel wells. If you wanted to remove your box and have the wires hidden, I guess you could tuck the wires back under the plastic panel that covers the spare. That's where my speaker wires come through to the box. You could make the connections on that side of the box so you could just disconnect them and hide the wires.
Old Apr 20, 2001 | 06:48 PM
myposcamaro's Avatar
how you doing?
its simple. I hid all my wires right under the plastic panel along the door jams. However, when you run your power wire and RCA's make sure there are on separate sides (run one along the drivers side, and the other along the passenger side)if you dont do this you will recieve a nice shocking sensation whenever you touch the cigarette lighter or open your door (puts hair on your chest, haha)
but anyway, just hide them right along the side plastic panels. You could probably just use your fingers and stuff it under, but if you wanted to go ***** out, then it takes a small phillips head to unscrew the panels.
peaceee
kev
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
blacksunshine'91
Interior Parts Wanted
Aug 10, 2015 12:04 AM
