Will subs cause knock retard.
Old May 10, 2001 | 08:28 PM
Stormshadow GTA's Avatar
1987 Trans AM GTA
305 5SPD
Hypertech airfoil
gutted maf
kn filter
High Flow Cat,
3"Walker pipe
Dynomax Super turbo Muffler
Custom Air Intake.
"Nothing To Fear all you see is my Rear".
Old May 10, 2001 | 10:54 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Um, no.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old May 11, 2001 | 10:05 AM
jobryan26's Avatar
'87 Trans Am:
(Engine)
305 TPI
180 Degree Thermostat
JET Fan Switch
TB Bypass
Accel 300+ 8.8 Racing Wires
Accel Super Coil
Bosch Platinium Plugs
Custom Ram Air with K&N
Removed Emissions Equipment & Cat.
(Stereo)
Full Kenwood Excelon System
Member at kyfbodies.org
Old May 11, 2001 | 03:51 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Wow, that'd be one helluva system! I'd imagine the rubber motor mounts isolate the engine pretty well. Something else to think of would be the current drain; I think you could be short-changing your ignition system if your stereo yanks too much power out of the charging system.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old May 11, 2001 | 08:11 PM
Jim85IROC's Avatar
<font face="Verdana, Arial" size="2">I'd imagine the rubber motor mounts isolate the engine pretty well.</font>
That's not actually the issue. Engine knock occurs at a frequency far out of the range of subwoofers. If subs could cause engines to knock, nobody's car would run when trains went by, or any time a hot-rod with an uncorked exhaust passed for that matter.
The IROC Homepage
RedLeader289
May 28, 2019 01:47 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
91 SrS
Oct 7, 2015 04:32 PM
meeklay812
Oct 1, 2015 03:46 PM
efiguy
Sep 27, 2015 01:30 PM
