polarity testing...
Old Feb 2, 2002 | 08:58 PM
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
polarity testing...
first of all....how can a speaker coil have a + and - side?? and what is that thing that stereo shops use to test polarity of speaker coils and how does it work?
Old Feb 2, 2002 | 10:29 PM
Allan's Avatar
Car: 1988 IROC-Z
Engine: 5.7L TPI
Axle/Gears: BW 2.77
A 9 volt battery. If the speaker pops out, you're good. You got the + and - right. If it pops in, you got it backwards.
Old Feb 2, 2002 | 10:44 PM
Engine: 2.2
I must be sleeping tonite.....
the coil magnetizes the cone and moves it.....ofcourse it has a + and - side....but is it really strait from a 9 volt? that seems like it would destroy some smaller speakers.
Old Feb 3, 2002 | 07:09 AM
Allan's Avatar
Car: 1988 IROC-Z
Engine: 5.7L TPI
Axle/Gears: BW 2.77
I generally use that for subs. i guess you're right on the smaller speakers. Usually, my smaller speakers are marked. i only had to do that battery trick w/ my subs. don't hold the battery to the posts long. just to check it move and that's it. it'll pop in or out
Old Feb 3, 2002 | 09:38 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I've tested the polarity on hundreds of small speakers, as small as 3.5" with a whizzer cone, and I haven't blown any yet. A 9 volt battery has very little current capacity, plus if you figure 9 volts through a 4 ohm speaker, that's about 20 watts, but that requires 2.25 amps of current, which that 9 volt can't get anywhere near.
my3rdgen
Apr 4, 2004 01:10 PM
AGood2.8
Nov 24, 2003 09:09 PM
a73camaro
May 4, 2003 02:20 PM
Steve89GTA
Car Audio
Mar 25, 2003 08:05 AM
NBG
Feb 22, 2001 03:14 PM
