HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Jun 30, 2001 | 06:45 PM
matty350TPI's Avatar
Ok so I was moving my amps around to the rack I built in the spare tire wheel well. Anyways now I don't have any sound when I fade all the way to the passanger side. None from the subs or the highs. If have attempted to check the RCA and they are all hooked up and I have checked to see if there is signal coming from both ends and I am pretty sure that I have a signal on both the red and white/black terminals. So why are my amps not putting out a right signal? HELP? Any ideas?
1988 IROC-Z T-Top "MATTSTOY"
350 Crate engine
370ft. lb Torque STOCK
5speed Centerforce clutch, Spohn Sub-frames, Jamex 1.5 Lowering springs, 2 1/2' Exhaust,ram air setup
Old Jul 1, 2001 | 02:48 AM
AmorgetRS's Avatar
You could of actually blown on channel in the amp. My friends RF amp did that, blew the right channel and that was the end of that...
Old Jul 1, 2001 | 12:25 PM
Is it possible to or just coincidence though that both my amps do the same thing? Could the deck not be putting one channel out? Both my sub amp and my high/mid amp are experiencing the same problem. No right channel. HELP
Old Jul 1, 2001 | 03:01 PM
Stoopalini's Avatar
Start by switching the right and left RCA's at the deck. If no change, work your way down the cables switching at every place possible (crossovers, amps, EQ's, etc...)
If the sound starts coming from the right, then you've found your problem.
If the sound never changes, then the amp is blown, or you have a short somewhere.
Good luck,
Thomas
