best kicker system...
Old Jul 31, 2001 | 10:37 PM
liquidinferno's Avatar
ok my plan for my car is...the first # is the # of total types of speaker not # of sets...
4 15" S15L7 kicker subs
4 7x10 I7103 3-way
2 ZR1000 amps
i dunno if im forgettin anything... does this sound like a good setup?
im takin out the back seats so i can put the subs there and the other speakers go on the door and window panels and if theres anything missin or left over ill put that beside that subs...
Old Aug 1, 2001 | 09:34 AM
Polecat's Avatar
A couple ideas I'll throw out to ya.
The ZR1000's are about 1100-1200 watts each. If you do an L7, do that per woofer, not per pair. The L7's like larger vented enclosures. They will gain between 3.0 and 5.9db in a vented enclosure.
I personally would do either two L7 15's in a vented box, like 6.0 cu.ft each, or two twelves. The twelved would work awesome in a 3.25 cu.ft enclosure tuned at 37hz. Be sure to add a sub-sonic filter.
Thetwelves are recommended to handle 750 watts, but they will handle a ZR1000 on each easily. People do it everyday and are getting really good numbers.
So check out our website ( www.kicker.com )for box recommendations, as it will help give yo dimentions and ideas on your enclosures.
But a good match would be two 12's and a ZR1000 on each.
Later.
morrow
Members Camaros
196
Jan 13, 2024 12:21 PM
92GTA
Apr 9, 2016 07:39 AM
RedLeader289
Sep 23, 2015 06:50 AM
R13_Braz
Sep 18, 2015 05:00 PM
JP84Z430HP
Car Audio
50
May 1, 2001 08:25 PM
