help!!!!!!!!!!!!!!!!!!!
Old Aug 6, 2001 | 07:51 PM
harvtherabbit's Avatar
can anyone tell me how to get at my front speakers with out breaking anything i got one corner of the grill up but it felt as if it would break if i pulled too hard and seems in there very tight any help will be greatly apreciated you guys have gave me lots of great ideas
Old Aug 6, 2001 | 08:24 PM
GndPrx's Avatar
Stop before you crack the clips under those grills.
You need to take the entire top dash pad out. There are like 7 or 8 (forget exact count) 7mm screws at the front lip of the dash underneath.
Take those out and lift up and pull out the dash pad. That will get you right to the speakers.
Carl
CarAudio Resources
Old Aug 6, 2001 | 09:05 PM
thanks that was my next idea kind of a crazy way to get to them but it allso explains alot........thanks again
Old Aug 6, 2001 | 09:11 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Don't forget the 4 screws in the defroster vents near the windshield.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Aug 6, 2001 | 09:18 PM
Ziggy89Formula's Avatar
There's also four screws in the top of the dash above the defrost vent you have to remove. Remove those carefully, because you won't be able to reach down far enough to get it if you drop one down the vent. I did that and had to MacGuyver a string and magnet to fish it out.
Those vents only come of from underneath, so it's pointless.
Old Aug 6, 2001 | 09:20 PM
Like Jim said.
89' Firebird Formula
Black/grey cloth
305 TPI/5 speed/3.45 rear
dual cats/PW,PL/T-tops
K&N, SLP TB booster,
SLP exhaust, Jet chip
