Ok, So what should I get
Old Aug 7, 2001 | 03:49 PM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
I'm going to order the kick panels, but what components should I get?
1. What 6 1/2 should I get?
2. What 6x9 should I get?
3. What amp should I get?
I already have a subbox and subs, 250W RMS
Any suggestions would be greatly appreciated.
Old Aug 7, 2001 | 05:17 PM
kurgen's Avatar
first of all, i wouldnt go with 6x9s unless you are on a budget, youre better off to get a set of components. but jbl makes good speakers in my opinion. if you have subs, you could just not get 6x9s, but get a set of 6.5 component or 2 ways for the front and have your subs in back, i have this setup in my corolla and it sounds mint.
</a href="http://www.myride.f2s.com/cgi-bin/ultimatebb.cgi>New Car Audio Forum</a>
http://wheels.at/CustomGM
Old Aug 7, 2001 | 05:19 PM
kurgen's Avatar
[This message has been edited by kurgen (edited August 07, 2001).]
Old Aug 7, 2001 | 07:53 PM
Funnyinaz?'s Avatar
Boston Acu. make some great speakers. I would go with a pair of their Pro 6.5's.
As for 6x9 you dont really need them, but if you get them tuned right it is so sweet. I would go with the Pioneer 4 ways. If you use a crossover, have your highs go to the Front, lows to the subs, and everything else to the 6x9s. And also give your Front more power than the back.
As for amps. Well it depends on how much power you can afford. Mabey something to match you sub amp. Really up to you.
Old Aug 8, 2001 | 01:11 AM
jobryan26's Avatar
What price range are you looking at for all this?
Trans Am:
(Engine)305 TPI
180 Degree Thermostat
JET Fan Switch
TB Bypass
Accel 300+ 8.8 Racing Wires
Accel Super Coil
Bosch Platinium Plugs
Custom Ram Air with K&N
Removed Emissions Equipment & Cat.
(Stereo)Full Kenwood Excelon System
See my Ride:
https://www.thirdgen.org/rides/index...ew&rideid=1324
Member at kyfbodies.org
Old Aug 8, 2001 | 09:04 PM
Kj Rockz's Avatar
Car: 91 Camaro 77K
Engine: 3.1 Vslick
I'd like to stay around 1K
