hooking up two amplifiers?
Old Aug 9, 2001 | 01:55 PM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
How would i go about doing such a thing? Both amps are 250 watts and able to be cross'd and bridged. Is it possible to do so? Their going to 2 10" Pioneer subs.
89 IROC-Z 350 TPI
-Flowmaster Catback
-Performance Resource Chip
-700R4 (Rebuilt) Too much done to actually list
-K&N Airfilters
-Ported Plenum
-2.77 Gears (not much to brag about but eh, its there)
-MSD 8.5 mm plug wires
-Gutted cat
-!AIR
-Gutted Air Boxes
Old Aug 9, 2001 | 02:54 PM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
I guess the better question would be can i just hook it up like the 1st one?
89 IROC-Z 350 TPI
-Flowmaster Catback
-K&N Airfilters
-Ported Plenum
-Gutted cat
-!AIR
-Gutted Air Boxes
Old Aug 10, 2001 | 02:53 AM
Shawn84SC's Avatar
The correct way is to install a distribution block on the power wire. If you don't want to spend the money on one, you can just run the power and remote off the other amp. Be sure to connect both grounds at the same spot on the body, don't connect the ground off of one amp to the ground on the other or you may get noise.
SRKLEGIN
Oct 29, 2015 06:38 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
mcfastestZ28
Oct 1, 2015 11:23 AM
Derrick86
Oct 1, 2015 05:12 AM
Gordonr1973
Sep 29, 2015 11:59 AM
