Attn: 84_l69_T/A
Old Oct 6, 2001 | 09:14 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Attn: 84_l69_T/A
Where in ohio are you??
I made up my mind on subs. Im going with 3 of the HEX 12's from Xtant.
I see you have memphis Amps Im looking at them also. Whice ones should I get??
mids/highs are Soundstream Exacts. 3 sets of 6.5 splits
Chris
1992 25th Anniv Z28 W/383 Stroker
AFR 210ccHeads/LPE Solid ROller Cam
Art Car 700r4/Strange 12Bolt
[This message has been edited by TPl383 (edited October 06, 2001).]
Old Oct 7, 2001 | 05:30 AM
IROCketZ28's Avatar
84_|69_T/A
If you're reading this thread anyway.... What sort of numbers are you hitting? Which class do you compete in? And I noticed you're from Ohio, and you're not running subs from ShockerAudio (Atomic Thunder)!! Yeah, Wayne's been giving Mike (Shock) a hard time about Finals this year, but the Shockers are still the loudest subs on the planet! Look at Ian and Jetro from right here in Tampa. 5 amps and 5 subs and hitting over 173 dB!! If you want to check them out, they're at www.shockeraudio.com . Either way, good luck next season!
'87 IROC Z28
SS 1-2 in dB Drag, Stk2 in IASCA IdBL
TPI 305
5-speed w/ Centerforce clutch
3 1/2" exhaust w/ Flowmaster
AFPR (set @ 46 lb)
TB AirFoil
Grant wheel
Custom short-throw shifter with leather boot
Pyle head-unit, Audio Control Epic-150 (Epicenter, SPL meter & voltage meter), Audiobahn 16V line driver, Autotek 4x100 mid/high amp, (2) Earthquake PH-D2 amps, (2) Shocker Audio 12" Shocker Xtremes w/ dual 1-Ohm coils in a 6.6 cu ft 4th order enclosure tuned to 45 Hz for SPL, 33 Hz for street. Polk/Eclipse front stage. Roughly 4500 W RMS. Good for 152.1 dB so far, shooting for 155 by the start of next season!
Check out my homepage and let me know what you think!
http://hometown.aol.com/ldaly33569/myhomepage/profile.html
IROCketZ28@caraudioclub.net
Old Oct 9, 2001 | 11:55 PM
84_l69_T/A's Avatar
hello,,,,Im from lancaster ohio,,,,My opinion on the amps is the memphis 1000d,,,
its mono block so you can add as many amps as you want,,,they just plug into one another,for example you can run up to 4-4 ohm
subs off of it at a 1/4 ohm at 1100 watts per speaker,,,but then you could just plug another amp in and bam, 2200 watts just like that, no extra wiring or nothing..you can add as many as you would like too,Ive seen guys with 18 of them run mono(18,800 watts)Plus its only 400 bucks an amp..if your close to lancaster find trafficjamz.just recently I pulled 157.5 with my system(an all time high)I compete in the 5-8 super street class,,,hope this helped,any other ?'s feel free to ask
Old Oct 9, 2001 | 11:56 PM
84_l69_T/A's Avatar
84 l69 T/A
5 speed, 373 posi rear
comp xe262 cam
hedman hedders and y-pipe no cat edelbrock pipe and areo chamber muffler
performormer rpm intake
holey 750 vac,,tuned for the 305
accel hei w/msd 6a box
wp sr 305 heads,
stereo, 8 memphis power bass 10's,2 memphis 1000d amps,ohio generator 140 amp alt,tsunami dry cell bat,set of memphis power reference 4x6's,and a set of memphis studio 6.5's with a memphis power bass 400 amp on the highs....dbdrag comp car
N.J.-SLICK-1
Aftermarket Product Review
Jul 31, 2014 09:15 AM
FatOldBastard
Jan 19, 2010 12:26 PM
NEEDAZ
Car Audio
Jun 23, 2005 07:15 AM
90TA
Jan 20, 2003 09:05 PM
