Help with speaker/amp resistance question
Old Oct 6, 2001 | 02:33 PM
TrueBlue91RS's Avatar
I need to know if it's alright to run a four channel amp with two of the speakers at 2ohms and the other two at 4ohms. Will this fry the amp, or is it acceptable? I'm running last year's model Clarion Pro Audio 5/4/3 chnnl amp that should be 2ohm stable. I just don't know the consequences of using speakers with different resistances. Thanks.
Old Oct 6, 2001 | 03:46 PM
Belker's Avatar
You're not bridging any channels, and the amp should be stable at 2 ohm stereo ... I don't see why there should be any problem. The amp should be able to handle this configuration.
Old Oct 7, 2001 | 03:51 AM
IROCketZ28's Avatar
You won't have any problems with running different impedence speakers off seperate channels of the amp. You will have to adjust the gains to balance the output, as the 2-Ohm speakers will get more power than the 4-Ohm ones. But the amp will handle a 2-Ohm load with no problem. Hope this helps a little!
'87 IROC Z28
SS 1-2 in dB Drag, Stk2 in IASCA IdBL
TPI 305
5-speed w/ Centerforce clutch
3 1/2" exhaust w/ Flowmaster
AFPR (set @ 46 lb)
TB AirFoil
Grant wheel
Custom short-throw shifter with leather boot
Pyle head-unit, Audio Control Epic-150 (Epicenter, SPL meter & voltage meter), Audiobahn 16V line driver, Autotek 4x100 mid/high amp, (2) Earthquake PH-D2 amps, (2) Shocker Audio 12" Shocker Xtremes w/ dual 1-Ohm coils in a 6.6 cu ft 4th order enclosure tuned to 45 Hz for SPL, 33 Hz for street. Roughly 4500 W RMS. Good for 152.1 dB so far, shooting for 155 by the start of next season! Polk/Eclipse front stage
Check out my homepage and let me know what you think!
http://hometown.aol.com/ldaly33569/m...e/profile.html
irocketz28@caraudioclub.net
[This message has been edited by IROCketZ28 (edited October 07, 2001).]
Old Oct 10, 2001 | 03:59 AM
Thanks for the info guys, that gives me a lot of different options to think about...
1Aauto
Sponsored Vendors
Nov 23, 2015 02:17 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
Armored91Camaro
Aug 25, 2015 12:01 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
