Part of System to Invest the Most $$$ into
Old Oct 11, 2001 | 09:31 PM
ADAM NEAL's Avatar
What part of a complete stereo system should I have the most money into to maximize quality and nice,deep,clean bass? Like an enclosure,subs,amp,cap,head unit,or speakers? An example would be to spend most of your money on the amps and spend less on subs etc. So what I'm asking is what part of the system should get the most focus and money? Thanks
Old Oct 11, 2001 | 09:49 PM
DJSexay's Avatar
front speakers. front speakers, front speakers.
Think about it, a sub is only playing the music from 80hz and down. The amps are just taking a signal, and making it bigger. The headunit is only reading ones and zeros from a cd and converting them to analog signals. The front speakers actually create the music.
If you were to switch between similar head units, or amps, you'd be hard pressed to tell an immediate and big difference. But no 2 sets of speakers sound the same.
Oh, did I mention front speakers are the most important part of a stereo ?
mike
custom 3rd gen kickpanels at
http://www.djsexay.com
Old Oct 11, 2001 | 10:00 PM
TrueBlue91RS's Avatar
The best building block to start with if you're looking for a lot of clean, powerful bass is a good quality amp (and that doesn't just mean high wattage!!!). If you just wanted mindlessly loud, muddy, pounding bass, then the sub and enclosure would be your first place to look. However, a good amp can make a lesser quality sub sound good, while the same cannot necessarily be said the reverse situation.
Don't get me wrong, though: I feel that some of the other factors (head unit, speakers...) are equally (or more) important to attaining a quality system, but for a primarily bass-minded system, spend more on the amp, and then look for a reasonable sub.
Old Oct 11, 2001 | 10:54 PM
OldOneEye's Avatar
Car: 1997 Nissan 200SX SE-R
Engine: 2.0 Liter SR20DE
Transmission: 5 Speed
Its all a series of links. A good amp will always be a good amp. CD players seem to change every year.
If I was building a good system, I would probably go with a nice amp first.
Closely behind (and maybe in front if you already have a smaller quality amp) would be to get nice front speakers and make sure they are put in right.
Bass in a car is easy to do. Cheap D class power, cheap subs that put out lots of bass. That is a walk in the park. Plus if you don't have it already, you really might not miss it.
Head unit might only be first if you don't have one now that plays CDs or if the one in your car is dead and want to get tunes NOW. Don't buy a cheap one though, or you might end up replacing it when you get new amps or front speakers. You usually get what you pay for.
Juan
1987 Pontiac Trans Am
1994 Nissan Sentra E
1999 Daewoo Leganza
Old Oct 15, 2001 | 12:08 AM
ADAM NEAL's Avatar
Thanks for the info guys.
Caspar
Jun 19, 2016 11:19 PM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
sreZ28
Aug 14, 2015 07:48 PM
1nastygta
Aug 8, 2015 07:38 PM
