Help Me Please!!!
Old Mar 21, 2002 | 01:19 PM
1986CamaroSC's Avatar
Car: 1986 Camaro SC
Help Me Please!!!
for the last time, i need to know how to bridge an mtx2300, i've tried and cant figure it out,
<img>http://members.aol.com/irocztpi1/mtx2300.jpg</img>
where do i put wires
Old Mar 21, 2002 | 01:21 PM
Car: 1986 Camaro SC
<img src="http://members.aol.com/irocztpi1/mtx2300.jpg">
Old Mar 22, 2002 | 08:28 AM
coalyard's Avatar
Easy. You do know that only one speaker can be driven in bridged mode, and with most amps, bridging will almost double output power, and raise total harmonic distortion. On this amp, the —wire of the speaker connects to the —right speaker output on the amp, and the +speaker wire to the +left speaker output on the amp. You cannot use the other channels in bridged mode, with a two channel amp, you are now running a monoblock, 1 channel.
I wouldn't suggest doing this with a dual voice coil sub that has the coils wired in series, since it would present a 2ohm load, and would probably cook the amp. Bridging fools the amp into thinking it is driving a lower resistance load to make more power. If you have a DVC sub with the coils wired in parallel, the sub presents an 8ohm load—to an amp in bridged mode, a 4ohm load, so you are back where you started.
I am assuming you are trying to power a subwoofer with this amp, right? How many subs do you have, and what kind are they? If I knew this, it would be easier to make a few suggestions for configuring them. Hope this helps.
______________________
1988 Camaro, 305 TBI K&N air filter
Stereo: Soundstream Reference 500, Reference 200, (2) Reference Class A 3.0 amps, A/D/S 326is and 325im speakers, (3) JL 8W6 subs
Old Mar 22, 2002 | 11:59 AM
Car: 1986 Camaro SC
when my sub gets here its an Audiobahn Alum12x, with dual 6-ohm voice coils and its 1000Wrms.
Old Mar 22, 2002 | 01:15 PM
Car: 1986 Camaro SC
on back of amp it says
for briged operation connect left(+) to mono speaker(s) postive terminal. Connect Right(-) to mono speaker(s) negative terminal. This amplifier can operate in Briged and Stereo modes simultaneously. Do not ground any speaker to chassis
so i guess you can run more than one speaker off it? but why does it say bridge over 3 terminals if you only use 2 of them??
Old Mar 22, 2002 | 01:43 PM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
It does not say bridge over 3 terminals. it lays it out very clearly. the postive terminal has a + and the negative has a - underneath it. you put the pos speaker wire where the + terminal is and neg where the - terminal is. its just two, not 3. see? Right negative and left positive are the ones you would use
Old Mar 22, 2002 | 07:51 PM
Car: 1986 Camaro SC
yeah i actually figured it out, but will running it in 3ohms briged all the time hurt it?
Old Mar 23, 2002 | 12:18 AM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
i myself am running an mtx blue thunder amp at 2 ohms bridged constantly. it all depends on how comfortable you are running somethin not suggested by the manufacturer. while mtx doesnt say 2ohms bridged is possible, my amp barely gets warm. but since i only paid $70 for the amp, it wouldnt be too big of a hit if the amp died. mtx is pretty solid equipment, so i dont think your amp will have a prob
