accelerator pump question (holley)
Old Jun 14, 2001 | 11:41 PM
brian86Z's Avatar
i have been playing with the primary pump on my 750DP. i have the black cam in position 2.the strange thing i notice is that is seems like the pump arm only moves about 50 percent of its total travel room. is this normal or not? i have tried different colored cams with the same luck. i recently upgraded to a 50cc pump because i could not get enough of a shot with the stock pump.
thanks for any help
Brian
Old Jun 15, 2001 | 01:38 AM
Big454blockchevy's Avatar
Car: 86 z28
Engine: Hyd. roller 498
Axle/Gears: 12 bolt 3.90 gears
Have you tried the yellow cam for a 50cc pump?
Big 454 72 Chevy Nova
383 86 Camaro Z28
10.5:1compression Dart Pro 1 Aluminum heads 215cc,234dur.488lift exh&int,Victor Jr. intake, 770 Holley Avenger vac.sec 400 crank,flat top pistons,tranny shift kit,2500 stall converter. 3.42 ,Hooker Headers,2.5inchpipes with 40 s. Flowmasters,MSD coil,MSD module.
Old Jun 15, 2001 | 08:25 AM
brian86Z's Avatar
no i did not try the yellow cam but the pump came with the orange cam. i thought the black was the mowt aggressive cam.
b
Frozer!!!
Jan 19, 2024 04:55 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
9192camaro
16
Feb 3, 2019 12:21 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
