Where is the computer bypass wire for timing
Old Jun 17, 2001 | 09:32 PM
bullfrawg's Avatar
I have an 85 TA and i can not find the computer bypass wire. My stickers are gone off of the hood. I am not sure it has the wire but if it don't what is the timing normally set on? I know the tbi cars are set to zero and the computer takes care of the rest. I have it set by ear now and it seems to run fine but i would like to set it right. Any info will help.
Old Jun 18, 2001 | 09:48 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Carb cars have a four-wire flat connector coming from underneath the distributor going to the engine harness (exactly where it is routed seems to vary from car to car). Mine goes between the distributor and accelerator cable, then back to the firewall harness.
Old Jun 18, 2001 | 06:25 PM
bullfrawg's Avatar
thanks. I found it. Do i set the timing on zero?
Old Jun 18, 2001 | 07:01 PM
Damon's Avatar
If you have the low output LG-4 305 you set it to 0. If it's the L-69 HO 305 I beleive the setting is 6 degrees BTDC.
Either way, you can EASILY advance it 4 degrees from it's stock setting for more performance, assuming you are using a stock chip.
eightsixseven
Dec 16, 2024 01:50 PM
Jae992
Aug 27, 2015 09:07 AM
TheExaminer
Aug 26, 2015 04:59 PM
jharrison5
Aug 19, 2015 05:53 PM
Thirim
Aug 9, 2015 06:19 PM
