just curious...
Car: 2001 Camaro SS
Engine: Almighty LS1
just curious...
To start my Z... it takes longer than it should... normally a few pumps of the gas pedal should make it fire right up right?
For me it takes a bit more than that...
but I'm thinking thats because of my timing...
would a timing too far retarded (say at about 600-650 for idle) be the cause of why it takes more to start up ?
Would it also be the cause for it popping through the carb?
I did what was suggested to me by replacing the airhorn gasket and a few other misc things but it didn't really help at all...
Anyone?
Anyone?
Car: 82 camaro SC
Start with the timing. As a test, set it to 8 degrees advanced. Running lean will also make it backfire, so check for proper choke function. When the engine is cold, the choke should be shut--check it before you try starting next time.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, current red metallic paint. Lots of other stuff...
82camaro
82camaro
