Fuel Pump(s) Question
Old Jul 1, 2001 | 09:03 PM
Changa2's Avatar
I just learned that the 87 LG4 came with an in-tank fuel pump. Did they also have the standard block mounted pump (with return line)?
Sounds like a dumb question but mine had an 84 L69HO transplant when I bought it. It does have the block mounted pump.
I'm just wondering about the original configuration for the LG4.
[This message has been edited by Changa2 (edited July 01, 2001).]
Old Jul 2, 2001 | 01:48 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I think the later LG4's had the same arrangement as the L69's, with a "helper" pump in the tank to lift the fuel to the mechanical pump. Earlier ones had just the mechanical pump. I don't know what year it changed.
Old Jul 2, 2001 | 06:46 AM
Biochem's Avatar
Car: 2002 SOM z28
Wouldn't an 87 have a TBI? If so, then it had to have had an electric pump at about 14psi right? Then if someone else put a 84 engine in there and used a mech pump... then they may have just disconnected the in-tank pump.
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
Old Jul 2, 2001 | 07:31 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Check out the "My Generation Camaro" article in this month's CHP. They have an '87 LG4, and it has both the in-tank pump and the block mounted pump.
I didn't know about the in-tank when I was doing my swap, and never checked the donor car before having it hauled away. Unfortunately, the hauling occurred before I heard about the in-tank possibility. But, the fuse panel doesn't appear to have a fuse for it, so I don't think it had it.
A long time ago, someone said the in-tank was a factory-supplied dealer-install if an owner complained about vapor lock. No clue if that's true, but I suppose it's possible.
My donor did have the little blower motor that blows cooling air on the carb when the engine is hot and shut off. It's mounted inside the fender by the battery. Does yours have that? Supposedly it was part of that vapor lock kit.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Old Jul 2, 2001 | 03:08 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
<font face="Verdana, Arial" size="2">Originally posted by Biochem:
Wouldn't an 87 have a TBI?</font>
LG4's were available until 87.
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
