what carb should i get?
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
what would work good on my stock 305 and still give my really good performance.....my bro said he would sell me his holley 600cfm with vacuum secondaries.....would this work with my car or is there better?
84TA T-tops L-69 305HO TH-700R4 stock 190hp and 240 ft-lbs.
best E.T. (dont laugh) 15.997 @86.04mph
http://www.geocities.com/K_towngangsta
Transmission: 4L80E/4L80E
There isn't anything about your q-jet that couldn't be made to perform better than your brother's Holley with just a few tuning steps. First is to make sure it allows the secondary AV to open all the way (see tech articles), second is to tune with rods & hangers.
What's really holding you back is cam & exhaust (and to some degree, heads). Before you could expect to see "really good performance", those issues should be addressed.
If you insist on going with the Holley, you'll need some type of spreadbore to squarebore adapter (yuck), or get an aftermarket intake to allow it to bolt on directly. You'll also need a vacuum/mechanical advance distributor, some means to lock up your tranny's TCC, and some way to disable that SES light that will stay on every time you start the engine (like take the bulb out). Gas mileage will probably suffer, too, if you're using it as a daily driver and are concerned about those things.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
RedLeader289
May 28, 2019 01:47 PM
efiguy
Sep 27, 2015 01:30 PM
