What Carb should I be running
Old Jul 23, 2001 | 02:57 AM
NORT's Avatar
First I just read the post that is a little down from this one about the 600 Eld. carb, and mine is acting the same way. The carb seems to be way to rich especialy at idle and also blows smoke when you put your foot in it. The carb has been jetted down once already but you folks think it needs to go more uh!. I guess I'll have to look into that. Now to my other question,I have had alot of different conversations with people about how big that I should be running. The motor is a 355 with(vortec heads,full length headers,flat top pistons,Preformer RPM man.,high preformance ignition,Comp 268 extreme cam 224/230 at 50 477/480 lift) As I had said before the motor has a 600 Carter Comp. carb on it right now and the motor seems to run well(13.82et./101.33mph at 106 degrees and 500ft. air)its about 9.7 to 1 compression. I live in Arizona. But the car at the top end has always seemed to be choked off or something just like it wants to run harder but can't. Do you folks think that I may be under carberated and do you think that a 750cfm. would help me out? I just recently put the 268 cam in it and wonder if I just need a little more carb. I know that it is rare to get just what you want but I have put alot of $$ in this thing and just want to get all I can out of it, as well as get rid of this smoke problem. Any coments anyone has will be greatly appreciated. Thanks NORT
Old Jul 24, 2001 | 11:42 AM
ChillPhatCat's Avatar
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
I would not run less than a 650 CFM on a 355... I would definitely recommend 750, just to keep from upping the carb size every time you increase the performance... at 750 you should experience no problems and better top end performance...
1984 Firebird T/A - Daily driver
305 LG4, T5 - Hurst Short Shifter
Edelbrock 600 CFM Performer Carb
Open Element Air Filter
Gutted Cat... missing stuff I'll need next year
IROC 16x8 Wheels
Goodyear P215/60/R16 87S - S stands for suck
(but I'm a cheap *** and I don't go 112... don't think I do...)
Quote from my sister: "It sounds like a boat"
Old Jul 24, 2001 | 02:25 PM
Jester's Avatar
Holley 750...definatly
Old Jul 28, 2001 | 01:23 AM
Phil87IROC's Avatar
Car: 1987 IROC Z28
Engine: 6.0L LQ9 crate engine
Transmission: Performa Built 700R4
Axle/Gears: 3.42 10 bolt, Eaton/Moser
I'd go 700-750 cfm for sure. My 383 has an Edelbrock 750 cfm carb and I may be going to a Holley 750 double pumper to get all the top end out of the motor like you desire. I may be interested in selling the Edelbrock carb if you want it. I live in Tucson, AZ. You can see the car run with it if you like. The carb has about 5,500 miles on it and I have alot of jets and rods and such.
Email me if your interested at:
parios@yahoo.com
Phil87IROC
Blue '87 IROC, 383 Crate Motor, KB pistons, AFR 190 heads, TPIS ZZ-9 cam, Edelbrock RPM intake, 1" TD spacer, Hooker SC/LT headers w/ Mufflex Y-pipe, Edelbrock 750 cfm Carb (#1411), Stock T-5, GM 3.42 gears w/Auburn posi.
Ohio Valley Dragstrip (KY) Trophy Bracket WINNER - 8.39 ET on a 1.82 sec. - 60'. Best MPH = 84.44. Still Tuning Carb!
Red '89 IROC L98, TES w/Flowmaster, 1LE DS, 700R4, T-Tops, K&Ns w/open air boxes, 160 T-stat, Hypertech Chip, gutted MAF & CAT, Jacobs Ign., 53kv coil, MSD wires.
[This message has been edited by Phil87IROC (edited July 27, 2001).]
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
86IROC112
Aug 17, 2015 02:00 PM
GVMV
Aug 16, 2015 08:01 PM
