how to power fuel pump after carb swap?
Old Jul 30, 2001 | 01:02 AM
stryduh's Avatar
i am in the process of completing a swap from tpi to carb and was wondering what the best or easiest way was to power the stock in tank fuel pump?
Old Jul 31, 2001 | 11:38 AM
BOWTIROC's Avatar
From: Coulterville, IL...Currently on Beale AFB, CA
Find the power wire, tap into it, and run direct power through a swithch to it.
Black 89 IROC...355, Solid Crower Cam, TFS heads.
12.0 @ 120.3mph with a 1.9 60ft...all motor
Old Jul 31, 2001 | 01:06 PM
Damon's Avatar
Find the power RELAY that the ECM normally energizes and activate it by connecting the trigger terminal to an ignition-switched power supply.
Old Jul 31, 2001 | 06:44 PM
camaro chick's Avatar
Listen to Damon!
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
Kaweh
Aug 9, 2015 02:54 PM
