ok TPS sensor
Old Apr 29, 2002 | 06:18 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
ok TPS sensor
i installed a TPS sensor in my q-jet a few months ago, i didnt have the tool to adjust it, but now i do, so i go to adjust it and on terminals B & C i get no voltage, if i put terminal B and then ground the other probe i get 4.80 volts at idle, then if i open the throttle it goes down to 2.something volts and stays there, is the TPS bad? i checked the wiring from the sensor to the computer and it checks out okay, i'm getting a code 21 and the car stinks, it's running rich.
db057
Jan 10, 2020 08:55 PM
92firebirdguy
Sep 1, 2016 07:53 AM
bbsr72
Apr 2, 2016 09:12 AM
Fred SS
Oct 12, 2015 11:27 AM
BWilcox
Sep 20, 2015 12:19 PM
