Do the 2 hoses from the Y-block to the bowls need to be the same?
Car: 2002 SOM z28
Do the two fuel hoses which run from the Y-block to each bowl (primary/secondary) need to be the same length? I assume so (which mine are currently), but I've seen fuel lines where the primary side is a lot shorter then the secondary line. Any thoughts?
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
Didn't you have to take any physics to get that bio/chem degree?
No it doesn't matter. you can have one line off the block 2" long and the other 200'. The only problem is any increase in length will impede the overall flow of the fuel to that half of the carb. Of course..you have to go longer than you could really fit in an engine bay if you tried before it really gets significant.
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
JSP Motorsports
ICON Motorsports
JSP Motorsports
ICON Motorsports
Car: 2002 SOM z28
Of course I took physics
That is why I'm asking... I was just wondering if the extra length would have an influence, especially after shifts when the rpms drop from 5000 to about 2500 or so. I am thinking that the psi does change a little when you are running that pump at 5000 rpms vs. 1000 rpms. I also guess the needle/seat/float/bowl size also allowed for fluctuations in psi/fuel volume a bit...
That is why I'm asking... I was just wondering if the extra length would have an influence, especially after shifts when the rpms drop from 5000 to about 2500 or so. I am thinking that the psi does change a little when you are running that pump at 5000 rpms vs. 1000 rpms. I also guess the needle/seat/float/bowl size also allowed for fluctuations in psi/fuel volume a bit... Thread
Pac J
May 17, 2020 10:44 AM
2012sergen11
Oct 13, 2015 07:38 PM
