Confused myself during Rebuild
Old May 4, 2002 | 03:40 PM
89 CamaroIROCZ's Avatar
I'm rebuilding a holley 650 DP. I confused myself a little bit tho. What side of the carb does the power valve belong on. The side with the choke or the side without it. Also which side does the leaner jets go on? Thanks.
Matt
Old May 4, 2002 | 05:44 PM
Blackened's Avatar
I'm very new to carbs and holleys in general but I DO know the power valve goes on the "primary" side of the carb and generally the leaner jets go on the "secondary" part of the carb. The primary being "the side with the choke on". I'm surprised you've never heard of these terms... I wouldnt even try a carb rebuild w/out a book if I were you.
Old May 4, 2002 | 06:05 PM
Thank you for your help.
Old May 5, 2002 | 09:13 PM
Cosmik Debris's Avatar
The leaner (numerically lower) jets go in the primary side also.
Old May 6, 2002 | 10:22 AM
So wait, the leaner jets (numerically lower.....) go on............... what side of the carb? I have them on the primary side ... but i see some conflicting information.
Matt
Old May 6, 2002 | 11:33 AM
Damon's Avatar
The lower numbered jets go on the primary side of the carb. I beleive this to be true in all cases with typical Holley performance replacement carbs (4bbls). Some factory applications might have it the other way around, but not the universal replacement stuff.
Old May 6, 2002 | 03:14 PM
Blackened's Avatar
He's right. I dont know what I was thinking when I said that but I should have said the leaner jets usually go up front! Doh... lol
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
hartsmike
Oct 2, 2015 07:11 AM
Derrick86
Oct 1, 2015 05:12 AM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
3.8TransAM
Sep 27, 2015 08:37 PM
