linkage
Old May 7, 2002 | 09:12 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
linkage
hey guys i am puttin a carbed 350 in place of my 305 tbi. i was wondering if i need to change any linkange? i was lookin ay it and it looks liek i just need to attach it somehow to the carb. how did u guys go about doin this and do u have any pics? thanks
Old May 8, 2002 | 11:15 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
You may just need to change the hardware on the cable, that connects to the carb. you should be able to use the same cable.
Old May 9, 2002 | 06:56 PM
IROC4LIFE's Avatar
Car: 1986 IROC-Z
Engine: SBC
Transmission: Manual Th-350
Axle/Gears: 9" Moser 3.89's Spool.
If you are using a Holley Carb and a 700R4 or 200R4 transmission you need to use the holley spec bracket.
This is the only way you will ever get your transmission to operate porperly
If you are using a Carter Edelbrock or Rodchester you will be able to reuse the stock brackets with some bending. Again this depends on your manifold
budowski
Carburetors
Oct 2, 2015 10:16 AM
mfp189
Sep 27, 2015 09:25 AM
IROCNParts
Sep 24, 2015 10:50 AM
Magman
Sep 14, 2015 01:30 AM
tonys91rs
Sep 2, 2015 07:07 PM
