Carb help
Old Nov 20, 2001 | 08:13 PM
bad86z28's Avatar
Carb help
First, I have an edelbrock 600 cfm carb on my car. For some reason, the throttle seems to be sticking a little lately. This is what happens. If I'm cruising along and I slowly take my foot off the gas, the rpms drop a little then they stick at some point, usually about 1200-1500. But, if I quickly take my foot off the gas it doesn't stick at all. I haven't had much of a chance to check it out, but when I do I'd like to have an idea of what to look for. Could by TV cable be holding it open? I have an electric choke so should I disconnect it and see what happens? Also when it sticks, if I quickly blip the throttle it'll act normal. Sounds like the choke to me, what do you guys think.
Black 1986 Z28
Hedman Headers, Edelbrock performer intake and 600 carb, Flowmaster cat-back.
Old Nov 20, 2001 | 08:52 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Check for interference between the throttle linkage and air cleaner.
Make sure the carb is torqued evenly to the intake. Do not use a thick carb gasket.
Dissconnect the tv cable and work the carb linkage to eliminate the tv cable as a cause.
Install a return spring on the lower part of the carb linkage and anchor it back on the
tv cable pracket so that it is parrallel
with the throttle cable and has enough tension.
[This message has been edited by F-BIRD'88 (edited November 20, 2001).]
Old Nov 20, 2001 | 10:12 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Check for interference between the fast idle cam and your throttle return spring too.
Old Nov 20, 2001 | 10:22 PM
bad86z28's Avatar
I don't know if this makes a difference, but I've had the carb for a little over a year and this has never happened. If you think there is something else I should check because of this fact please let me know. I'm still going to do everything else suggested though. Thanks for your help.
RedLeader289
May 28, 2019 01:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
efiguy
Sep 27, 2015 01:30 PM
