What to remove during carb swap
Old Dec 8, 2001 | 09:12 PM
IsuzuMini's Avatar
I am gonna do a tbi-carb swap in about 2 weeks on my '92 RS I am thinking a Performer RPM intake, Performer 600cfm electric choke carb, and an open element K&N, at this time I will also swap in a new cam (dont know which yet) my new distibuter will be an MSD. I am not sure what kindof fuel pump to get yet any suggestions on that would help. But what I really want to know is How Much horse power gain I can expect? and the big one: What other things can I take out(o2 sensors etc) and where the different things are located. Also what cars did the Bowtie and/or double hump heads come on(for project Monte Carlo)
Thanks guys,
Stephen
85 Monte Carlo SS:
355 with a comp cams street/strip cam, Comp cams lifters, Speed pro pistons, Performer RPM intake, 600cfm performer carb, Hooker Comp Headers, K&N 14x3 open air filter
Old Dec 10, 2001 | 10:48 AM
Damon's Avatar
Your existing in-tank electric fuel pump will work with the carb will work just fine as long as you use a bypass regulator to get pressure down to about 6 PSI. TBI systems run at about twice that usually an it will flood out a carb.
As for the rest of it, I believe there is a tech article on the board that discusses this exact swap.
I beleive the Performer RPM is a bit much for that engine and will also cause hood clearance problems with the carb and air cleaner. I'd go with the standard Performer intake.
[This message has been edited by Damon (edited December 10, 2001).]
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Jan 29, 2017 07:00 PM
NBrehm
Aug 25, 2015 11:49 PM
cstrobel65
Aug 15, 2015 10:19 AM
3rdgenparts
Aug 8, 2015 07:09 PM
