Amazing Bog in Q-junk
Car: 06 Toyota Tundra SR5
I tweaked my AV tension a long time ago, but recently I replaced spark plugs and spark plug wires with 8mm accels. But the bog is still there, running a little better but when I punch the gas pedal, nothing, and then a second later it will slowly accelerate until it gets about 3k and then it really pulls. Could this problem be that the tension on my AV flaps are too loose?
Transmission: 4L80E/4L80E
Could also be a malfunctioning choke pull-off. You need both the pull-off and AV tension adjustment to make it work properly.
ah, well i dotn knwo how to adjust that lol. But I just lossened the screw all teh way, and slowly rotated it till it shut, tighted the tork underneth and flipped the flap and it will not shut unless i pull it all the way open then it will just sit there.
That's too loose. The AV tension should be at least 1/4-1/2 turn in the closing direction from just closing.
Hotrodboba400
Dec 10, 2019 07:07 PM
RedLeader289
May 28, 2019 01:47 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
